| Power Supply: 13,8 V | Frequency Counter | Dummy Load 50 ohm | Oscilloscope |
| RF Power Meter | DC Amperemeter | RF SSG | AF SSG |
| Fine | Mid. |
| Clarifier | Mid. |
| SQ GAIN | Max. |
| AF GAIN | Max. |
| RF GAIN | Max. |
| MIC GAIN | Max. |
| NB/ANL | Off |
| MID Band, Ch. 19 | Frequency: 27.185MHz |
| Reading Point | Condition | Adjustment | Procedure |
| PLL | |||
| IC2 Pin 8 | - | Check | 10.2400MHz |
| TP1 | RX AM | L14 | Maximum on Oscilloscope |
| TP9 | RX AM | L13 | VCO Coil - 4 Volt |
| RECEIVER | |||
| RX USB | L10 L9 L8 | RF | |
| RX USB | L7 L6 L5 L4 L3 | IF 7.8MHz | |
| TP6 | RX AM | L1 L2 | Noise Blanker |
| TRANSMITTER | |||
| TP9 (+) TP8 (-) | TX USB | VR8 | 10mA |
| TP9 (+) TP7 (-) | TX USB | VR9 | 50mA |
| TX USB/LSB | VR5 | Modulator Balance | |
| TX AM | L26 | Maximum (TX-Mixer input - 7.8MHz) | |
| TX AM | L27 | Maximum (TX-Mixer input - RF) | |
| TX AM | L28 | Maximum (TX-Mixer output) | |
| TX AM | L29 | Maximum (TX-Mixer output) | |
| TX AM | L56 | Maximum |
| Pin | Description |
| 1 | Microphone |
| 2 | Microphone Ground |
| 3 | Speaker/TX Ground |
| 4 | Ground |
| 5 | TX |
This counter shows the number of hits since the 7th March 1999
