Alignments
Cherokee AH-27 Alignment Procedure
Transmitter alignment
STEP SETTING CONNECTION ADJUST ADJUST FOR
1 RF Driver stage;
Mode: Transmit
Volume: N/A
Squelch: N/A
CH: 19
Connect oscilloscope
probe to base of
Q18
T9
T10
Adjust for
Maximum wave
form on the
oscilloscope.
2 RF Power Stage;
Mode: Transmit
Volume: N/A
Squelch: N/A
CH: 19
Connect dummy
load and RF power
meter to the external
ANT-Jack.
T11
RV-105
Adjust for Maximum
indication on the
Power meter, not to
exceed 4Watts
3 Second Harmonic check;
Mode: Transmit
Volume: N/A
Squelch: N/A
CH: 19
Connect RF Power
meter with dummy
load to spectrum
analyzer through
coupler -40dB atten.
to EXT ANT jack.
¼ At no modulation,
compare the level
of fundimential
freq-spectrum to
the level of
harmonic freq-spectrum.
Suppression of the
2nd Harmonic must be
down at least 60 dB.
4 Frequency Check
Mode: Transmit
Volume: N/A
Squelch: N/A
CH: 19
Connect dummy
load and frequency
counter through
coupler to RF Power
meter. Also connect
power meter to
EXT-ANT jack.
CT-2 Make sure that the
indication of the
transmitter frequency
is 27.185 MHz +/- 300Hz
on the frequency counter.
5 Modulation check:
Mode: Transmit
Volume: N/A
Squelch: N/A
CH: 19
Connect dummy
load and modulation
meter through
coupler to RF Power
meter. Also connect
power meter to
EXT-ANT jack.
RV-4 Adjust for 90% +/- 5%
indication of modulation.
Receiver alignment
1 RX Sensitivity;
Mode: Receive
Volume: Fully Clockwise
Squelch: Fully Counterclockwise
CH: 19
SSG: 28.185MHz, 1KHz Audio tone
1 uv(-107dBm), 30% AM modulation
Connect RF signal
gererator to external
ANT Jack. Connect
SSVM, Sinadder and
distortion meter
across EXT-SPeaker
output jack with 8 Ohm
load resistor
T1
T2
T4
T5
T6
Adjust the parts
of tuning circuitry
with observing ADM
"Automatic Distortion Meter"
indicates 10 dB S/N in AM
mode, and adjust output level
of RF-SSG until speaker
out level reaches about
500 milliwatt (2.0 Volts)
-adjust for Maximum
indicatiom ON¼SSVM
2 Squelch Adjustment:
Mode: Receive
Volume 500mW(2.0V)
Squelch: TIGHT
CH: 19
SSG: 28.185MHz,
1KHz Audio tone
2.815 uv(-38dBm),
30% AM modulation
Connect RF Signal
generator to external
ANT jack. Connect
RF Power meter and
distortion meter across
EXT-Speaker jack with
8 Ohm load resistor.
RV-1 Adjust the point until the
audio output appeared
on scope
3 Squelch Adjustment:
Mode: Receive
Volume 500mW(2.0V)
CH: 19
SSG: 28.185MHz,
1KHz Audio tone
100 uv (-67dBm),
NO¼MODULATION
Connect RF Signal
ANT jack. Connect
RF Power meter and
RV-2 Adjust so that the
9th LCD Bar display
on the LCD signal meter
has just been set.
This counter shows the number of hits since the 30th August 1998
Go Back To The Alignments Page
Go Back To The Home Page
http://www.radiomods.co.nz/
