need help with microphone wiring ??
- belfiglioval
i have a astatic D-104 table mic, with a four pin connecter, i am changing it to a five pin so i can use it on my cobra 2000 GTL, there are six wires for this microphone, blue, white, green, red, brown, shield, i cant find any info for a mic this old, thanks.
hello,,the white wire should be the audio wire,the red wire should be the transmit wire,the brown wire should be the recieve wire,the blue wire is you switch wire..for 5 pin common,should be as follows..pin 1 is the audio wire or white wire.pin 2 is the shield wire.pin 3 is the recieve wire or brown wire..pin 4 is the common or switch wire or blue wire..pin 5 is the transmit wire or the red wire............ramblingman p.s...your other two wire are non connect
belfiglioval, have a look at this link. Might be useful.
http://www.cbcintl.com/docs/mikewire.htm
cheers
Paul.
cheers
Paul.
