Cobra 29 NW LTD
turbo
Cobra 29 NW LTD
Post by turbo »
Radio has no audio on TX . 4 watt dead key , RX is fine , Mic is good .PA dose not work . what could this be ? has any one seen this problem before?
Re: No TX audio Cobra 29 NW LTD.
You should have more than .4 watt so check D8 it sounds like its open circuit. You may also have a bad driver and or final TR15 and TR14
These radios are known to have trouble with cold solder joints, so maybe a good idea re-solder around audio amp and output stage.
RedEye
Post by RedEye »
Was that .4 watt or was it supposed to be four watt deak key? I can't tell if that is a period for the previous sentence or not....
If you meant the radio has a Four Watt dead key with no audio or PA audio,
If RX is ok, but no PA or modulation, possibly the mic or mic input circuit?
turbo
Post by turbo »
Yes , that is a typo . should read four watts . Finals appear to be good . tested on a dosy test center . Also radio makes correct frequency per channel .
Re: No audio Cobra 29 NW LTD.
Sorry I read as 0.4 of a watt and PA working well in that case change the audio chip.
Post by frogman296 »
Rick wrote: change the audio chip.
what he said...seems as though a pile of the newer style 29's have that issue
turbo
Cobra 29 nw ltd
Post by turbo »
well every one , you all were wrong . This what was finaly found . The pot on the dynamike was broke , after changing the ta7222 it still had the same symtom . Now working fine . this concludes this repair 8)
James Unit 198
Post by James Unit 198 »
before i would have asking any question i would check that all the controls and switches was working a ok. the first post was not very good.
Min
Re: Cobra 29 nw ltd
Post by Min »
turbo wrote:well every one , you all were wrong . This what was finaly found . The pot on the dynamike was broke , after changing the ta7222 it still had the same symtom . Now working fine . this concludes this repair 8)
And thanks to you too
