Uniden Washington Keys Up, No TX & No RX
Scarecrow
Post by Scarecrow » Thursday 7th Feb 2008, 15:26
This radio powers up but there is no RX and Tx... Keys Uo and Needle swings as you modulate but will not transmit and also will not recieve... On SSB Mode the needle doesn't move and still Has No TX & RX... Any help would be appreciated...
73's
Post by ramblingman » Sunday 10th Feb 2008, 16:54
check ic-5 and d-60
frogman296
Heavy User
Heavy User
Re: Uniden Washington Keys Up, No TX & No RX
Post by frogman296 » Monday 2nd Mar 2009, 7:45
where the devil is d60??
i cannot for the life of me see that diode
The Defpom
Site Admin
Site Admin
Post by The Defpom » Tuesday 3rd Mar 2009, 14:42
D60 is mounted between pin 2 of the MB3756 and 0V, it is on the track side of the PCB, it was a factory addition, to help protect the device, not all radios have it in place, if not add it.
frogman296
Heavy User
Heavy User
Post by frogman296 » Tuesday 3rd Mar 2009, 18:13
The Defpom wrote:D60 is mounted between pin 2 of the MB3756 and 0V, it is on the track side of the PCB, it was a factory addition, to help protect the device, not all radios have it in place, if not add it.
so its a 1n4004 type?? or a 1n4148??
so i solder it from pin 2 to chassis ground??
The Defpom
Site Admin
Site Admin
Post by The Defpom » Tuesday 3rd Mar 2009, 18:20
It should be an 18V Zener diode.
frogman296
Heavy User
Heavy User
Post by frogman296 » Tuesday 3rd Mar 2009, 18:28
The Defpom wrote:It should be an 18V Zener diode.
stripe towards the IC??
frogman296
Heavy User
Heavy User
Post by frogman296 » Tuesday 3rd Mar 2009, 20:18
thanks scott
much appreciated
