cobra 148gtl no sound
scott3696
Post by scott3696 »
i have a 148gtl made in taiwan it transmit and recieves according meter but no sound through internal speaker or external speaker. i've changed mics no difference, i also changed ic5 chip no difference except that chip gets warm now where before it didnt. any clue or help. thanks.
magsy
Post by magsy »
check the ic 6 ta7222p is a audio amp
THE LAND OF PROMISE
DAVAO CITY
PHILILIPPINES
scott3696
Post by scott3696 »
yeah what do i need to check on ic 6
scott3696
Post by scott3696 »
i also noticed if i put two or three of my fingers on board just right i could here some sound
scott3696
Post by scott3696 »
i changed that ic chip mentioned before now the ic gets hot and still no sound
Re: Cobra 148gtl No RX audio.
Try unsoldering one side of R87 and D65 to see if the audio returns.
scott3696
Post by scott3696 »
hey rick thanks for info but it did not seem to help any but i can here a little static in speaker if i hold it up to my ear any other suggestions thanks
Check all the caps around the audio chip, like C175, 176,179 and 180. Let us know on how you get on.
scott3696
Post by scott3696 »
hey rick i'm still green at this what do i need to check voltage or ohms or what. thanks
scott3696
Post by scott3696 »
scott3696 wrote:hey rick i'm still green at this what do i need to check voltage or ohms or what. thanks
and also do i need to solder r87 and d65 back in. thanks again
Yes solder R87 and D65 back in place, as you are green, it would just be easy to replace the caps and hope for the best or take the radio to some one who can fix it for you. sorry I could not be more helpful, but I am very busy.
scott3696
Post by scott3696 »
sorry to bother thanks anyway
That ok. Let hope that so one else is more helpful than I was.
scott3696
Post by scott3696 »
replaced caps C175,176,179,180 and no difference still no sound
scott3696
Re: cobra 148gtl no sound
Post by scott3696 »
finally got this 148 fixed replaced caps again around audio chip and came to life thanks guys
