I have made a big mistake! "President Lincoln"
wiking
Post by wiking » Tuesday 17th Mar 2009, 6:33
Radio Make and Model:UNIDEN President Lincoln.
PCB Number:PB-121AC HCT-58NY 94V-0
Cpu Prom UC-1201A
Test gear available:Freq,counter,Volt/amp meter,Funk gen,sinad meter,Fm dev/Mod/Watt meter,Dummyload.
Symptoms:No reading on the display it's total blank,No TX,No bleep when push buttons,Can not change freq.
What is working:Normal radio noise on Cw Lsb Usb Am Fm,RIT is working,Squelch is working
What has been tried:Replaced 1000uf 6,3 V condensor,Replaced 7805,Shift J301 and J307.
Did it suddenly happen ?:No after replaced all the 10V condensor on the main board i connected the Pll board and I mixed up by mistake the J301 and J307. :banghead:
Anything else that may be of help?: The condensator1000uF 6.3 V, became very hot and started to swell like a balloon.The ceramic disk cond,on the top of the UC-1201A became
very hot,No voltage from the 7805 ok after replace :doh:
IC 315
1. 0 V 15. 0 V 29. 4,94 V 43. 0 V 57. 0 V
2. 0 V 16. 0 V 30. 4,94 V 44. 0 V 58. 5,16 V
3. 0 V 17. 5,17 V 31. 4,98 V 45. 5,16 V 59. 5,16 V
4. 0 V 18. 0 V 32. 5,12 V 46. 5,16 V 60. 5,16 V
5. 0 V 19. 5,10 V 33. 4,91 V 47. 5,16 V 61. 0 V
6. 0 V 20. 0 V 34. 5,15 V 48. 5,16 V 62. 0 V
7. 0 V 21. 0 V 35. 4,69 V 49. 1,28 V 63. 0,79 V
8. 0 V 22. 5,17 V 36. 1,26 V 50. 5,12 V 64. 5,16 V
9. 0 V 23. 1,25 V 37. 5,16 V 51. 4,20 V
10. 0 V 24. 5,10 V 38. 5,16 V 52. 4,83 V
11. 0 V 25. 1,91 V 39. 5,16 V 53. 0 V
12. 0 V 26. 2,00 V 40. 5,16 V 54. 0 V
13. 5,17 V 27. 4,82 V 41. 5,16 V 55. 0,91 V
14. 0 V 28. 4,92 V 42. 5,16 V 56. 1,78 V
IC 316
1. 5,16 V 4. 1,49 V 7. 0 V 10. 5,17 V 13. 5,16 V
2. 0 V 5. 5,16 V 8. 2,37 V 11. 5,17 V 14. 5,16 V
3. 5,16 V 6. 5,16 V 9. 2,37 V 12. 0 V
Could it be the IC UC-1201A that is gone or the IC 316?
Regards
Per Andersson
P,S Thanks for you share with us your knowledge!
You are doing a great job. 73 51
PRESIDENT LINCOLN
Re: I have made a big mistake! "President Lincoln"
Post by The Defpom » Tuesday 17th Mar 2009, 14:13
It sounds like you have shorted out the MPU, you will have to find another one to replace it with.
In the worst case I would be interested in buying the radio from you for parts.
wiking
Post by wiking » Friday 27th Mar 2009, 12:41
Thank you Scott!
It was the the CPU/MCU that was blown :x
So to all CB people that have a Uniden hr2510/2600/2830/Lincoln be careful not to mix the connectors you will destroy the radio if you get them wrong I have tried :banghead:
Regards Per
PRESIDENT LINCOLN
