Uniden pc68xl NO TX power
Posted: Saturday 28th Mar 2009, 7:41
Radio Make and Model: uniden pc 68xl
PCB Number: PA-339AB1/4
PLL Number: NPC 992D SM5126BP
Test gear available: BK 1040, BK 2040, watt meter, Multimeter
Symptoms: radio has great modulation on BK 1040, but zero watts
What is working: the only thing that i can find that is not functioning is the tx power
What has been tried: replaced driver, final, cb/pa switch... replaced caps , c91, c118, audio chip, Q16.... i had changed r43 to a 4.7ohm as part of a mod...along with adding caps to c42, 46...have since removed the added caps..
Did it suddenly happen ?: yes
thanks in advance
thanks in advance
