Cobra 2000 GTL Sideband Issue.
speedracer6g
First Name: Michael
Post by speedracer6g » Wednesday 10th Jun 2009, 0:53
Radio Make and Model: Cobra 2000 GTL
PCB Number: pc-497aa
PLL Number: 8719
Test gear available: Motorolla Service monitor R-2200b, Freq Conter, Digital and Analog VOM, Ect...
Symptoms: I am having trouble alligning the sideband on this radio. I can get the tx to line up perfectly but as soon as i go to set up rx the fun starts. If i can even get the rx to line up it throws the tx off again. Something is wrong in the sideband section maybe there is someting sorted that is causing the two frequencies to mix? any help would be appreciated.
thanks,
Mike
RBR762
First Name: Robert
Re: Cobra 2000 GTL Sideband Issue.
Post by RBR762 » Monday 22nd Jun 2009, 7:45
I am having a similar problem with my 148gtl-can you tell me how you are lining up the transmit and recieve,in other words wich cans for the receive and wich ones for the transmit etc...
Robert
NightRanger3151
Post by NightRanger3151 » Monday 22nd Jun 2009, 20:46
Maybe this will help ....
13EL121
First Name: Ralf
Post by 13EL121 » Friday 26th Jun 2009, 1:15
NightRanger3151 wrote:Maybe this will help ....
Hmmm...this looks nearly same like President Madison :!: :?:
carlospo
First Name: Carlos
Post by carlospo » Thursday 8th Oct 2009, 13:30
You got a solution? What? I have the same problem, will be the PLL?, bought a new switch but when the radio did not have audio.
