148 gtl needs aligned
First Name: Robert
Post by RBR762 » Sunday 21st Jun 2009, 14:46
Radio Make and Model:148 gtl-china
PLL Number: mbb8719
Test gear available:frq.counter/volt meter
Did the clarifier mod found on this site and a re-alignment found on cb-tricks.
After the mods i checked the radio only to find out that with the clarifier knob centered it is 4 kc off freq. when i transmit, and on sideband i have to slide 4-5kc to tune anyone in.
Should i change the 1K resistor (R175) to a different one to decrease the slide travel,it slides 5 kc up and 11kc down right now.Also should i mount a 8 volt regulator in the radio and use it for the clarifier instead of using the positive side of C84.
HELP! Robert
