Rotel 240 noisy TX
mm3stb
First Name: Richard
Rotel 240 noisy TX
Post by mm3stb » Friday 14th Aug 2009, 3:04
Radio Make and Model: Rotel 240
PCB Number: PTBM134A0X
PLL Number: LC7137
Test gear available: Digital VOM, Analogue VOM, Frequency Counter, Dummy Load
Symptoms: Noisy TX
What is working: Everything
What has been tried: Switch cleaner mic gain VR. Checked connectionm
Did it suddenly happen ?: Fault was presant when purchased
I have a Rotel 240 that is realy noisy on TX. sounds like a windy mic but i have tried throwing out a dead carrier (shorting the mic pins) and it's still noisy. Appart from that it's working perfect. Is there anyone with suggestions
Re: Rotel 240 noisy TX
Post by The Defpom » Sunday 16th Aug 2009, 1:32
Check the PCB for any signs of cracked traces or bad solder joints, years ago when I still lived in the UK I have one of those with the same issue and it was caused by a PCB fault.
