Radio Make and Model: mirage 88
Test gear available:
Symptoms: channel indication
What is working: bought this way
What has been tried:
check for loose connection
Did it suddenly happen ?:
Anything else that may be of help?: yes, on the channel switch the offest for channel 22-25 is working right.
what this radio is doing is the channel indicator does not indicated the right channel in the right band. band d channel 30 is 27.305 right on channel 19 is 26.865. i cannot find regular 1-40 us band.
now this is not a linear problem band c shows have the displacement and band b shows 19 as higher than the frequency indicated on channel 30. can anyone help me out with this abortion? thanks
mirage 88 frequency problem
Re: mirage 88 frequency problem
nvr mind burned trace back side of board with trademark broken solder joint on it. its all great now thanks anyhow 73
