Cb not receiving
mckinleyhorse2
First Name: Charlie
Cb not receiving
Post by mckinleyhorse2 » Friday 30th Nov 2012, 10:11
Radio Make and Model: Cobra 25 NW ST
Test gear available: multimeter, soldering iron, solder
Symptoms: no reception on any channel. The needle does not move. It will move to about 3/4 when you key the mic, but I do not know for sure that I am transmitting.
What is working: Lights up, powers on, -----PA works----- everything appears to be fine except no reception and the squelch, gain etc do not change anything.
What has been tried: Checked the speaker and mic.
Did it suddenly happen ?: It worked fine and one day I turned it on and the problem started.
Anything else that may be of help?: My antenna a wilson 5000 the mount broke and the cb was keyed up several times. Someone told be i had bad finals, and someonesle said if the needle moved when I keyed up then the finals were good and the audio chip is bad. I have a TA7222AP audio chip, I can get one for about 3 bucks. Should I test something first or am I way off.
I am not a cb expert, any help would be appreciated. I did search the forum first, but did not find anything similar. Thanks in advance to anyone who takes the time to help.
zodiac
Re: Cb not receiving
Post by zodiac » Wednesday 5th Dec 2012, 2:24
Charlie,
All I can tell you is, if the PA is working then the audio chip is good and not the fault.
Bowwowwow
First Name: Mike
Post by Bowwowwow » Tuesday 1st Jan 2013, 7:12
Check Some caps around the audio chip, big and medum ones, if that doesnt do it, replace the audio chip.
The Defpom
Site Admin
Site Admin
Post by The Defpom » Tuesday 15th Jan 2013, 20:39
I suspect that it has overloaded the front end of the RX chain, most probably the shunt diodes, D1,D2,D19,D20.
