cobra 29 audio/mod transformer hot!!!!
Bowwowwow
First Name: Mike
Postby Bowwowwow » Tuesday 1st Jan 2013, 6:08
Radio Make and Model: Cobra 29 classic
Test gear available:
Symptoms: Audio/ mod transformer red hot within sec (smoking) as soon a power is appied
What is working: mic switch is not stuck, drops to 0.
What has been tried: d8, d23, replaced. Audio chip?
Did it suddenly happen ?: turned up slugs, might of touched something
cbsupertech
First Name: Michael
Re: cobra 29 audio/mod transformer hot!!!!
Postby cbsupertech » Friday 4th Jan 2013, 21:26
Hey Dawg...
Find the short, don't flail around guessing and hoping you replace the right one..
Desolder the leads/ find out if the winding's shorted to the other winding...see if your load is shorted to ground...read the print!!! C'MON!!!
••••••• Std. TECH PRACTICES/ TROUBLSHOOTIN 101 •••••••
I personally suspect your mod transformer itself is shorted...either internally to the core or secondary winding...
IT HAPPENS!! :banghead:
...especially with the low quality-made in china transformers
If you're smart you'll get the print and use your head, not yPour wallet!
wayword son
First Name: christopher
Postby wayword son » Sunday 31st Aug 2014, 11:49
hello,
having the same problem,soldered a 47 ohm 1/2 watt resistor for talkback now no audio.
everything else seems fine P.A. works through the mic. cobra 29 ltd classic built in aug. 2013.
replaced the audio chip. I get transmit until that chip gets hot then nothing
thanks for any help
Who is online
Users browsing this forum: No registered users and 8 guests
cron
