98vhp no transmit
zinger827
98vhp no transmit
Postby zinger827 » Monday 27th May 2013, 12:41
Radio Make and Model:
PCB Number: EPT690010D
Test gear available: vom meter, freq. counter
Symptoms: No Tx.
What is working: Everything.
What has been tried: Tried replacing mosfets. irf520's
Did it suddenly happen ?: yes
zinger827
Re: 98vhp no transmit
Postby zinger827 » Tuesday 28th May 2013, 0:35
Hi I am getting
q47 - 5.70v rx on drain gate 0.00rx - 3.75tx 0.00 on source
q48 - 5.56v tx on drain gate 0.00rx - 3.82tx 0.00 on source
of finals
q49 - 5.70v rx on drain gate 0.00rx - 3.90tx 0.00 on source
driver
I do have another radio on beside it and does show a carrier and when touch the drain on finals shows more of a carrier on other radio but no modulation. Meter on 98 shows no output like the other radio shows a little signal.
The amp is totally disconnected from radio. The amp is fine just the main board has no Tx power.
zinger827
Postby zinger827 » Wednesday 29th May 2013, 9:03
Looking at schematic I'm getting 6v to L31 and C200 but from C200 to c201-c202 and c197 not getting the 6v power? Would that keep me from getting Tx out? If I touch them other coils with meter lead it gets a signal reading on my other radio but no RF out?
zinger827
Re: 98vhp no modulation
Postby zinger827 » Monday 3rd Jun 2013, 2:20
Ok I got Tx back the L44-43-42-40 was out of align. But I still have no modulation? Plus I get a 120+ watt deadkey on SSB? Rx is fine. ic7 is good.
Users browsing this forum: Bing [Bot] and 12 guests
