FeedBack Problems
Rooster9507
First Name: Nathan
FeedBack Problems
Post by Rooster9507 »
I have just installed a cobra 29ltd classic, I have it hooked straight to the battery and I am using a 102" stainless steel whip. The radio works great but the problem is I am getting real bad feedback from my car through the CB Speaker :banghead: . I have the noise blocker switch but when I use it I lose some of my range. Is there anything I can do to prevent this from happening? I would appreciate any help at all thank you.
Neo1130
First Name: Kyle
Re: FeedBack Problems
Post by Neo1130 »
I would start by checking power connection. Make sure your ground has 100% good contact. Remove paint/dirt/rust and go bare metal.
Neo1130
First Name: Kyle
Post by Neo1130 »
Also when running wire don't go parallel with other wires. Cross at 90 degrees when possible...
hamradiotech
First Name: Clint
Post by hamradiotech »
Is the feedback your referring to be AC alternator whine? Can you add additional information to the feedback issue. Thanks
