Major M588
M6MRP
First Name: Phil
Major M588
Postby M6MRP » Thursday 11th Dec 2014, 5:41
Radio Make and Model:
Test gear available:
Symptoms:
What is working:
What has been tried:
Did it suddenly happen ?:
M6MRP
First Name: Phil
Re: Major M588 (found the problem)
Postby M6MRP » Wednesday 17th Dec 2014, 23:09
Problem sorted guys :D , checked all relevant resistors all ok, then started checking relevant caps and found a dead ceramic! C22 .047uf (first dead one Ive ever seen?) and replaced that with a decent high Q mylar version from my electric guitar tone junkie parts then found C24 listed as 39pf had been replaced with a 27pf so swapped that out with trimmer cap to test and swung it on TX, the TX frequency easily swung from the old UK 27/81 FM -3.7kHz off-set back to the proper 5.0kHz ending, C22 and C24 are part of the fixed bias parallel feed for the clarifier from Q4 for anybody who is interested.
Phil
Who is online
Users browsing this forum: Google [Bot] and 14 guests
