pro 2006
Posted: Monday 31st Jul 2006, 7:17
by pink148
Hi all.
After some time of not getting swiched on my realistic pro 2006 scanner has developed a strange fault. Every 2 seconds or so the damn thing keeps on beeping and it has a batt thing flashing on the display all the time.I have put a new 9 volt battery in but made no difference at all.
Please can anyone help me solve this problem...
Thank's for any help i may or may not get.
Posted: Friday 29th Jun 2007, 6:33
by ShoreLine
Is it the U110 or the U501?
2006
Posted: Thursday 23rd Aug 2007, 16:15
by warhorse
Hi, 2mnths odd out of date but try this site most of the dwn loads still func.
http://www.repeater-builder.com/radio-s ... index.html
Re: pro 2006
Posted: Saturday 30th May 2009, 22:28
by process0
hello. how u find realistic pro 2006 scanner. is it oK. what is the price and tell us about the features of this scanner
Re: pro 2006
Posted: Saturday 6th Feb 2010, 2:30
by Tipsy
I know this is an old thread but in case anyone finds it searching for the same symptoms, I found the cure. Simply replace the batteries, then RESET to Factory Defaults - Both Realistic Pro's I've owned are reset by holding the 2 and 9 buttons down then turn on - you will lose all stored frequencies and custom settings unfortunately but at least the BATT LO problem is sorted. HTH someone.
Re: pro 2006
Posted: Friday 19th Feb 2010, 22:08
Tipsy wrote:I know this is an old thread but in case anyone finds it searching for the same symptoms, I found the cure. Simply replace the batteries, then RESET to Factory Defaults - Both Realistic Pro's I've owned are reset by holding the 2 and 9 buttons down then turn on - you will lose all stored frequencies and custom settings unfortunately but at least the BATT LO problem is sorted. HTH someone.
Hi, Thanks for the info on how to resolve the issue, I am sure that it will be of help to someone who comes looking for info on the same fault.
Re: pro 2006
Posted: Friday 1st Mar 2013, 23:00
by aden045
hello. how u find realistic pro 2006 scanner. is it oK. what is the price and tell us about the features of this scanner.............
Re: pro 2006
Posted: Thursday 5th Dec 2013, 23:19
by corbingravely
Just reset it to factory defaults. Make sure there is no more pending works in the printer. If there is something left then reset the work or stops printing completely. This should work I guess. If this doesn’t work then god knows what will.
CORBIN GRAVELY
