tube tester ????
Forum for technicians, to bounce ideas off each other.
speedracer6g
First Name: Michael
tube tester ????
Post by speedracer6g »
wondering what is the best tube tester to get or most poplular for working on radio equipment. want ot make an investment for my shop and dont want to waist my money on one that wont do the job.
Thx,
Mike :?:
rstroupe
Tube Testers.
Post by rstroupe »
The tube tester I use is a Jackson Dynamic Tube Tester, make sure it's a "Dynamic Tube Tester" so you can check the plate current. Some tube testers do not give accurate good/bad tube under dynamic conditions. Any tube tester you would get I suppose will test most tubes you'll need to test. Since there are very few numbers still manufactured like the 6L6, and the beam power tubes. Don't forget your tester will need a cap to connect to the anode for testing the high power tubes.
"...I've got to keep on chasing that dream, though I may never find it... I'm always just behind it..."
