talkback rely
bigboy250
talkback rely
Post by bigboy250 »
any body have any on how to put a talkback rely in and take out factory one? on a gen. lee
Dodgem250
talkback rely
Post by Dodgem250 »
you want to do what now? Take out a talk back relay? Email me with some details, I don't quite understand the issue.
Dodgem250@somd.net
timrim
talkback rely
Post by timrim »
All you will need to do is simply remove all wires, near the external speaker jack, you will find a jumper that this relay went to, you will need to install the PCB jumper back in that spot. The relay is glued down, so gently pry up from board. As for putting it back in, I don't recommend using the relay method, I just don't like it. If you need to have a decent talkback, and adjustable, I always use the Magnum Universal Talkback board, they are awesome!
Return to “Tech Area”
