Galaxy 959 10kc mod question
UncleT
Post by UncleT » Friday 30th Nov 2007, 16:02
Hi all,
http://www.cbtricks.com/radios/galaxy/d ... kc_mod.htm
Does anyone know if the SPDT switch is a ON/ON or ON/OFF/ON switch?
Thanks
UncleT
Min
Post by Min » Friday 30th Nov 2007, 17:18
I would have to say "on, off, on"
switch up 10kc up
center off (normal freq)
switch down 10kc down.
but wait for a few replies as I could be wrong as I have not done 1 of these yet. But it sounds pretty right to me.
Min
Post by Min » Friday 30th Nov 2007, 17:21
sorry, just went to the link you provided. Read the info just under the pic.
It says "spdt on-off-on switch"
I was right.
UncleT
Post by UncleT » Sunday 2nd Dec 2007, 17:51
Thanks, guess I missed that part :oops:
Post by frogman296 » Sunday 2nd Dec 2007, 19:38
did you get the mod done yet, uncle t??
Re: MB8719 10KHz jump.
Post by Rick » Monday 3rd Dec 2007, 6:10
My diagram on CBTricks maybe easy to understand. Check this link.
http://www.cbtricks.com/members/rick_eu ... c_jump.pdf
UncleT
Post by UncleT » Sunday 9th Dec 2007, 16:22
frogman296,
no. every time I pass the electronics store I don't have my parts list :x
No hurry on my part anyway. I will get to it though. I'll add the results to this post when I do.
Thanks Rick, I'll reference it when I dig into the radio. I like the slide switch idea. :wink:
Min
Post by Min » Sunday 16th Dec 2007, 19:22
Its been a while now UncleT, hows the progress comming along???
Surely by now you`ve gotten the parts needed.
UncleT
Post by UncleT » Tuesday 18th Dec 2007, 17:51
Hi Min,
Mater-o-fact I just picked up the parts today. I think I'm going to go back and get a flip switch instead of the slide switch. After playing with the slide switch I think it may be hard to find the center position while driving. Plus you only have to drill a whole for a flip versus cutting a square for a slide.
I probably will not touch the radio till after x-mas. I had time tonight but instead fixed my home stereo that got hit by lightening.
Have a good holiday.
UncleT
Post by UncleT » Saturday 22nd Dec 2007, 5:31
Well I got the 10kc mod done.
It basically gives you 5 new frequencies to use.
26.955 (channel 4, switch down)
27.045 (channel 8, switch down)
27.095 (channel 12, switch down)
27.145 (channel 15, switch up)
27.195 (channel 20, switch down)
Cheers. :wink:
Thanks Rick for the additional schematic.
Re: Galaxy 959 10kc mod question.
Post by Rick » Saturday 22nd Dec 2007, 5:41
The 10KHz switch is only to give you the A channels 3A, 7A, 11A, 15A and 19A, and the channel switch giver you the rest. What was you expending to get?
UncleT
Post by UncleT » Saturday 22nd Dec 2007, 6:04
Hi Rick!
Guess I was revising my post while you responded. I had a brain fart this morning after putting the radio back it the truck then reviewing the frequencies and found the ones the mod added. Thanks for your help.
UncleT
UncleT
Post by UncleT » Saturday 22nd Dec 2007, 6:16
Well see if this works. Attached is a photo that shows where I installed the switch (left side in front of mic connector).
Post by frogman296 » Saturday 14th Feb 2009, 13:14
Rick wrote:The 10KHz switch is only to give you the A channels 3A, 7A, 11A, 15A and 19A, and the channel switch giver you the rest. What was you expending to get?
can this mod be done in addition with the "2 switch" channel mod for the mb8719?? the switch on pin 10 and the switch between pin 11 and 12
reason i ask is... the 2 switch mod...doesn't give 27.4450...it does give 27.4550... ideally i want to have " channel 44 "
thanks in advance
Post by frogman296 » Sunday 22nd Feb 2009, 0:13
anybody?
goffiefarmer
Post by goffiefarmer » Saturday 3rd Apr 2010, 18:36
cbtricks has the 10kc mod
Max Kujath
