Mod for Higher Dead Key With Cobra After ERF 2030 mod
StrightClaw
Post by StrightClaw » Sunday 30th Mar 2008, 23:56
I ran across this on another forum and found it to work realy good for the Cobra 29.It may be of use to some.
Add a 1/4 watt 4.7 ohm resistor from the + side of C116 to the gate of the 2030 this is the left leg looking at the face of it. Replace C62 with a 390 PF Cap. The post suggest to jump D8 but I left mine alone. Went from 2 watt dead key to 8 watt.This will also incress the swing.
Now my question is does anyone know if this can be done to the Cobra 25 and how ?
speedracer6g
First Name: Michael
Post by speedracer6g » Wednesday 7th May 2008, 12:07
Sure can!!
-instead of using a 4.7k use a 10k pot or 100k. set your gate voltage to about 2.7 to 3volts. Do this by putting a voltmeter on left most leg of the mosfet final when looking at the face of the transistor.
-remove C45
-remove C46 and install a 480pf capacitor.
Also do not put a jumper on D8 because that is bad I have seen radios go up in smoke that diode is there to prevent feedback into the audio ciruit.
happy modding
Mike 8)
Shadow
Post by Shadow » Saturday 4th Oct 2008, 7:32
speedracer6g wrote:Sure can!!
-remove C45
Call me blind, but I don't see a C116 in the Cobra 25. Can someone tell me where it is located?
Shadow
Post by Shadow » Wednesday 22nd Oct 2008, 1:02
Hey Mike, since there is no C116 on the Cobra 25, where do you solder the other end of the pot?
speedracer6g
First Name: Michael
Re: Mod for Higher Dead Key With Cobra After ERF 2030 mod
Post by speedracer6g » Sunday 14th Jun 2009, 5:54
Sorry I might have that wrong I will check that agian and get back to you.
MIKE
speedracer6g
First Name: Michael
Post by speedracer6g » Tuesday 16th Jun 2009, 7:18
On a Cobra 25 it goes on the center leg of tr16. Sorry about that.
MIKE
