Hi guys, great site!
Ive reading thru the forums but find nothing that can helps me.
Im new in radio world.
I get a licence to transmit in 10 meters but my radio (superstar 3900 EPT 360014b board) covers 11 meters and just a little portion of 10 meters.
In my coutry it is forbbiden to transmit in 11 meters.
can anyone helps me to mod this radio to tune 10 meters?
Ive tried the mod of 12 and 13 pin of the IC7, but doesnt worked out.
Any sugestions?
NAcho.
Superstar 3900
Re: Converting Superstar 3900 to 10 meters.
If your radio is fitted with the X2 crystal of 14.010 MHz then replace crystal X2 with 15.360 MHz.
You will need to do a full realignment on the radio.
Superstar 3900
mmm.....Realignment...
I think ive seen a realignment procedure somewere...
can it be done by an amateur??... isnt there an alternate way?
Thanks a lot for your help
You need the right test gear to do the job right.
RF signal generator (100 MHz).
RF power meter and dummy load
A standalone frequency counter (at less 6 digit).
10 to 1 probe
SINAD meter.
There are no short cutes
10 to 1 probe
SINAD meter.
Superstar 3900
Thats true for almost everything heheheYou need the right test gear to do the job right.
Thanks a lot !!
