modifying a radioshack htx 10 10 metre radio 25.160 to 30mhz
- Light User
hi everyone, i seen a radioshack htx 10 a 10 metre all mode radio this 1 was modded from 25.160 to 29.999mhz. ,the guy wouldnt show me inside it but he said if i got him 1 he would give it to someone who knows how to mod them ,they look like a dragon 485 etc ,has anyone seen or owns a modded htx 10 all mode ,radio, if so can you still get them ,thanks dave from australia
However, seeing as you want the HTX10 info, which is somewhat different, I found this...
1.open radio look up on front face board if you look very carefully you will see 2 solder pads where there could of been 2 pins for a jumper plug you will see one side goes to a smd and the other goes to a ground island, solder a resistor of 10 ohms across the pads
Now put the radio back together and hold 'fun' and button 2 in while turning on.
The radio will have a 40 channel display on right of freq display 1-40
Press 2 to change bands along w/ lower left button'
THERE is NO fine mod for radio due to missing components.
Frequency Shift
1. Press the fine tune knob for "func" and then the shift button until shift+ or shift- are selected, as desired
2. Press "func" again and HOLD DOWN the shift button, a three digit number representing the shift will appear
3. Change the shift with the tuning knob
4. Key the mic to go back to normal mode
Transmit "shift"...
The radio has a transmit offset (shift) for repeater operation and it can also be used to work split frequency.
The amount of offset can be changed but it can only be changed in 10 KHz steps.
Fine tuning control
The Fine Tune control on the front panel effects TX and RX
Frequency Shift
Transmit "shift"...
Fine tuning control
- Light User
hi scott, is the newer model the same or just buy 1 used off ebay, david
No idea, I have never seen a HTX10, I have worked on a 485 though.
I found the above info after doing a quick search.
