A-99 Fiberglass "splinters"
Group,
I have a Solarcon A-99 Base antenna with the grounding radial kit. It was purchased used, and is several years old. It is now installed and working very well, but.........during the installation I found out that the fiberglass was shedding very sharp pieces when touched (used leather gloves after first touch ). I know it is not a problem now that the antenna is in the air, but what might be the best way to curtail this type of damage in the future. Will using a clear spray of some sort keep the fiberglass in better shape, without causing any detrimental Xmit/Recv issues? What is the preferred preservation method on fiberglass antennas? Thanks all....
Joe
Joe
What did you decide to use to spray your antenna? I do have some spray lacquer on hand, and will most likely be raising the antenna by about 10' soon anyway. So, might take that opportunity to set it on some benches on the ground and spray it then.The Defpom wrote:I actually use an A99 myself, I spray painted my one when I noticed the original covering was gone from the surface when I repaired a broken top section.
As a side note, I tried to use Photobucket to host my photos and post them here, but seems that your system decided they were a spam attempt. Are we limited to the use of the built in image hosting methods then? Not a problem, just limits things a bit sometimes is all.
Thanks for your comment, and I look forward to more in the future....
Joe
Electrons-Not just for breakfast anymore....
I think the original finish is something called a gel-coat (as used on marine craft hulls etc)
Rub yours lightly (not too much or you'll go blind!) with aluminium oxide abrasive cloth (about 60 grit) then give it another coat.
Finish off with some SWR bees-wax & a chamois leather for a hi-gloss finish
antron etc
pref the last post-pure class.nice 1.
About three rolls of self Amalgamating tape does the trick make more stable with pvc elec tape on the thin bits, or use large heat shrink if you can get. no the prob, rays of the ultra violet break down the ariels fibreglass body.
http://www.cbradiomagazine.com/Feb%2020 ... seller.htm
http://www.n1wpn.net/antron_99_exposed.htm
antron etc
- Light User
hi avenger, ive had mine for 10 years nearly its the origal antron 99 ,ive heard of the solarcon getting it id use some good apoxy or resin type material or some heatshrink ok ,im located in australia ,thx david nsw
