cobra 148GTL 5 pin radio wiring needed Please.
For any general discussions, if your posts topic matches one of the other forums do not post it in here, use the correct forum for the topic.
thundir
Post by thundir » Tuesday 24th Mar 2009, 6:28
Can Someone please help me :roll: . I have a Cobra148GTL 5 prong Mic Radio. I want to wire up a echo power mic called TS2024C Trucker Series Mic to this Radio. The mic has 5 wires. Colors are Blue, yellow, shield, black and red. I was hoping you can give me the color to pin wiring configuration. Like pin #1 is Shield and so on. Im sure blue is the Audio. I believe this mic is just like the DM452 power echo mic under a different name.Thanks Guys...........John.
15minigrass
First Name: James
Re: cobra 148GTL 5 pin radio wiring needed Please.
Post by 15minigrass » Tuesday 24th Mar 2009, 20:24
cant find anything on that mic but it looks like the same colors as Astatic. Here a site. Yellow is not connected
http://www.hamtechnet.com/techtips/mikewiring/11 Most Popular MIC Wiring Diagrams.html
thundir
Post by thundir » Wednesday 25th Mar 2009, 13:51
Hi 15minigrass. When i go to the site hyperlink this is what i get....Not Found
The requested URL /techtips/mikewiring/11 was not found on this server.
Apache/2.0.52 (Red Hat) Server at http://www.hamtechnet.com/techtips/mikewiring/11 Port 80
15minigrass
First Name: James
Post by 15minigrass » Wednesday 25th Mar 2009, 15:45
try this and click on "Most common mike wiring"
Return to “CB Radio General”
