Hi All: Picked 1 of these up from ebay at a good price, wondering if any of you nice people might have a user manual or Data sheet for it & if so could you email me a copy.
hello, i was wondering if you have the plug in crystals for the front. i also bought one and cant find info anywhere, after searching for 2yrs i gave up. then about 6mo ago i put up for sale at a local cb swap and an old timer lt me know that i didnt have the plug in crystals for the front and it was useless, whether thats true or not i dont know.
anyway i just thought id pass that along, good luck, take care
Hiya & thanks for the info: As far as I know you dont need Xtals to go in the front the 2 sockets are used for quick Good / Bad testing of Xtals, it won't tell you the actual Xtal fequency but will tell you if it's capable of sustaining oscillation. The bottom scale is marked Xtal: Good or ?, do you still have the meter? i'm taking this 1 into the workshop tomorrow to fit a new battery connector & check it out. Will let you know the results.
Classic CB wrote:Hiya & thanks for the info: As far as I know you dont need Xtals to go in the front the 2 sockets are used for quick Good / Bad testing of Xtals, it won't tell you the actual Xtal fequency but will tell you if it's capable of sustaining oscillation. The bottom scale is marked Xtal: Good or ?, do you still have the meter? i'm taking this 1 into the workshop tomorrow to fit a new battery connector & check it out. Will let you know the results.
Regards: Andy @ Classic CB
hello andy
yes i still have the meter, as of today its just a good conversation peice on my media center.just cant get any proper readings out of it. it looks like a top notch peice. i dont have any paperwork on it, maybe im not using it properly.
let me now what you find out.
thanks for your time ......allen
Hi Allen: Sorry it's taken so long to reply but been a bit busy, unfortunately the old timer who said you need Xtals for the Reace was right. The circuit inside the unit is a colpitts oscillator with tripler so for whatever channel you want to transmit a test signal on you need a xtal approximately 1 third the channel frequency, so for example channel 20 would require a 9.263 Mhz xtal to be plugged in the front. I suppose it was easier to do this than fit a channel switch with a PLL type oscillator, without the xtal plugged in you get no signal generation of any kind not even AF. The meter will still work as a Power/SWR meter though.
