texas ranger tr-396fc
- perrym1962
Is it possible to unlock the clarifier in this am only radio? I have found the mod for the ssb models but not these.
Re: texas ranger tr-396fc
What is the point, where are you going to go with it?
- perrym1962
Pick up the in between channels
There is no point as you AM carrier is 10 KHz wide and if you was to go up or down let say 5 KHz you would be ? 5 KHz in each adjacent channel, this is not very clever and not make you any friends.
- perrym1962
I was talking about sliding 10 khz to get 3a, 7a, 11a, 15a, 19a. I'm sorry for asking. Later....
- perrym1962
P.S. I have lots of friends....
Re: texas ranger tr-396fc Alpha channels.
To get the Alpha channels you need to do the following, Locate the PLL (RCI 8719) and cut the track which go to Pin 16 (PLL) solder across the cut a 4K7 resistor, solder a wire to Pin 16 (PLL) solder the other end of the wire to the centre pole of a SPDT switch (You can use a switch like a CB/PA), next solder a wire to Pin 18 (PLL) and solder the other end of the wire to the top pole of the switch, and finally solder a wire from Pin 9 to the bottom pole of the switch. This is very easy to do and takes about 10 minutes to complete. If you can not follow this give me you email address so I can send you a diagram.
Am I your friend now?
- perrym1962
