grant lt
perrym1962
grant lt
Post by perrym1962 »
I have a grant lt that I did the pll conversion on. Radio works perfectly except for the channel display. I touched a trace with the solder pen in the area between the pll and the channel selector ribbon and the display went very dim and then went out. I replaced the led but that is not the problem. :oops:
Re: grant lt.
Check out http://www.radiomods.co.nz/forum/viewtopic.php?t=312 As there are 4 different models you need to let us know what you.
perrym1962
Uniden Grant LT, Phillipines, MB8719, Ser.#96004025
Re: Grant LT no dispaly.
As you have not given us the PCB number. I can only guess what to try TR28 or TR401, check to see if the transistors are OS.
perrym1962
PB-208ad is the only # I can see..
Try replacing TR28 to see if cure the fault.
perrym1962
It is marked Q28 which I am sure is the same. I will find another one and try this. Thank you for your time..
perrym1962
That took care of it. Thank's Rick and I do appreciate your time..
