REALISTIC NAVAHO ??
For discussions on CB Radio Alignment and Tuning
belfiglioval
REALISTIC NAVAHO ??
Post by belfiglioval »
Hello, can anyone tell me how to tune a navaho base station or any mods?? thanks
frogman296
Heavy User
Heavy User
Post by frogman296 »
what model? most of the realistics are limited
Min
Post by Min »
:?: which model base station do you have and what is the board number?
What are you thinking of doing to it also?
:idea: help us with some info on your radio and what your intensions are and we might be able to help or point you into a direction of help.
belfiglioval
realistic navaho,
frogman296 wrote:what model? most of the realistics are limited
hello, its a trc 490,
frogman296
Heavy User
Heavy User
1) Grab the radio with both hands with the front of the radio facing you.
2) Elevate the radio to a position around your belly button.
3) Walk to the nearest trash can. (A trash dumpster will do in a pinch)
4) While grasping the radio with your left hand, use your right hand and remove the lid from the trash can.
5) Elevate the radio just above the trash can and release the radio.
6) While still holding the lid of the trash can, replace lid.
7) Turn exactly 180 degrees and walk back the way you came.
That's it! Its that easy!
on a more serious note...
cut r104
am vr6
ssb vr7
tr 32 is the AMC
also....you can add channels...You have to replace the 11.1125mhz crystal with a 11.3258mhz crystal before doing this mod.
i can post a pic showing how to do the channel mod if you'd like
Min
Post by Min »
Or if you like, do a search in yahoo on "The Mod" and you will find a extremly good mod for your radio. No cutting of tracks/drilling holes for switches and you use the same 11.1125MHz crystal that your radio already has.
If you have this mod installed in your radio, your rodio will appear stock looking with no added switches but will not be stock. You`ll have a cool 3 digit display and a whole lot of channels. If you ever deside to sell the radio you could pull the mod out and make it back to stock and no one will ever know that is was ever modded.
You have a good radio that will work well with this mod.
Its worth having a look at.
Min.
frogman296
Heavy User
Heavy User
i have seen the mod as well...NICE piece of work..
Min
Post by Min »
that mod can be done to any radio that has the mb8719pll.
Min
Post by Min »
I am currently do 2 radio with The Mod.
President P400 & Uniden Grant (silver face).
I will post pics once they are completed.
frogman296
Heavy User
Heavy User
Min wrote:I am currently do 2 radio with The Mod.
i can't wait to see them done...is the mod hard to install in the 2000??
Min
Post by Min »
It is very simple, but I am limited to time. Plus the other half doesn`t want me in this room as much. She seems to think I spend more time with my computer & cb`s than I do with her.
Join the yahoo group. Everything is there on making the board and installing the mod.
marveylus22
Post by marveylus22 »
Min could you pm me the link to the group? Thanks.
Min
Post by Min »
marveylus22, PM sent
marveylus22
Thank you sir
When the Boogeyman goes to sleep every night he checks his closet for Chuck Norris.
Min
Post by Min »
No problem
Uncle Ray
Post by Uncle Ray »
Hey I'd love to have a look at this , can you send me a link.
Regards.
Ray
Min
Post by Min »
I have previously posted where you can find all the info in this mod.
Just go through the posts and do some reading.
Hint: its in this thread.
Uncle Ray
Post by Uncle Ray »
right.......
Min
Post by Min »
Sorry frogman296, I just noticed that I didn`t answer your question.
I haven`t done 1 to a cobra 2000, but from what I have read in the forum it is very simple. You`ll just have to change the crystal to a 11.1125MHz and the pll to a MB8719pll. Do an alignment then install the mod which isn`t all that difficult.
There are a lot of people in the forum that have done 2000`s so you could ask question in there if your not to sure on something.
The 2000 looks very nice with the mod.
I have attached a pic of one of the group members Cobra 2000 GTL with the mod.
Post by ramblingman »
the trc-490 is a good modding radio..it has the same p.c.b..as the uniden washington..pc-385..you can modd it for channels pretty easy..also there is a npc mod that gives this unit excellent audio upgrade....any mod you find for the uniden washington with the pc-385 pc board should work for your radio......
