grant lt
- perrym1962
grant lt
I have a grant lt that I did the pll conversion on. Radio works perfectly except for the channel display. I touched a trace with the solder pen in the area between the pll and the channel selector ribbon and the display went very dim and then went out. I replaced the led but that is not the problem.
Re: grant lt.
Check out http://www.radiomods.co.nz/forum/viewtopic.php?t=312 As there are 4 different models you need to let us know what you.
- perrym1962
Re: Grant LT no dispaly.
As you have not given us the PCB number. I can only guess what to try TR28 or TR401, check to see if the transistors are OS.
- perrym1962
Try replacing TR28 to see if cure the fault.
- perrym1962
- perrym1962
