Marine antenna
Marine antenna
Does anyone know if running a ground wire to the antenna base of a non ground plane fiberglass Shakespere marine antenna to the stainless steel handrail that surrounds a 28' fiberglass boat would help on the receive being the antenna is mounted to fiberglass. Thanks John
Marine antenna
Thanks kc8mob makes sence to me I'm actually on the Monongahela river 30 mile south of Pittsburgh but I'm sure its the same principle. I'm allways in a deep valley with high hillsides on both sides so I'm allways looking for better ways to get good reception out of the deep hole and read someware that vhf signal is pretty much line of sight .Thanks John
Re: Marine antenna
The fault is most like to be on the PRT Unit, which is at the bottom for the radio just above the battery connectors, as this PCB is SMT board when I get one in with this fault I just replace the PRT Unit.
If you want to do some digging around on the PRT check Q1, D1, and D2 if you have a later W2 check R4 as maybe open.
