Galaxy DX66v Doesn't like remote speaker
warlock820
Post by warlock820 »
Radio seems to work fine until I plug in a remote speaker, Then it howls to no end! Have tried 3 different speakers and it does the same with each. Using a ASTATIC 636 mike. :shock:
Earl "WARLOCK" Walker
galaxy dx66v-doesnt like remote speaker
Post by ramblingman »
hi there,does the radio have talkback.and does it howl with the talkback on or off........ramblingman
warlock820
more info on galaxy
I did some more searching and think I found out what's wrong. Radio has been peaked. According to dxzone, this will cause my radio to squeal thru a hardwired talkback circuit. would you agree that to solve the problem I need to cut a jumper wire on the board??
Thanks for getting back to me on this! :D
galaxy dx 66v-doesnt like remote speaker
hello again,well if it was me i would cut j-15 jumper,and install me a spst toggle switch in rear of radio.so i could have switchable talkback,.also do the mod shown on dxzone.com.add a 470k resistor from the junction of c154/r207 to the junction of c187/r235.this is a good mod,ive tryed this one.it is good for a peaked radio it will stabilize your talkback and make it sound cleaner.go to www.dxzone.com/cgi-bin/dir/jump2.cgi?id=2482 and this will show you where to put the resistor on the solder side of the pc board......good luck with your radio.......ramblingman
warlock820
mod to galaxy
Thanks for the advice. I will install the switch and the resistor.
