dx-88 melts protection diode
Posted: Sunday 1st Jul 2007, 10:50
by tim_spur
i have a galaxy mirage 88 was having problems with no audio so put a new audiochip in now as soon as you hook it up to power it melts the protection diode put another new diode does the same thing whats wrong here
dx-88-meltes protection diode
Posted: Sunday 1st Jul 2007, 12:40
hey there,you are installing the audio chip correctly ahy.it has to be installed with the numbers facing the heat sink.also check your solder connecions making sure two patterns are not touching each other.
ok
Posted: Wednesday 4th Jul 2007, 7:15
by tim_spur
well i installed the chip in the exact way the old one was in with numbers facing the inside of the cb and was carefull not to bridge any connections is that the wrong way
dx-88-melts the protection diodes
Posted: Wednesday 4th Jul 2007, 10:02
yep,thats the problem,youve installed it backwards.the numbers on the audio chip should be facing the heat sink.in other words you shouldnt be able to see the numbers once its installed,the side that has the little round dot in the middle,should be facing the inside of the radio.better put a new one in now through.cause that ones probably toast.........ramblingman
coolll
Posted: Friday 6th Jul 2007, 6:10
by tim_spur
ok damn your good thats probally why my dx-44 doesnt recieve either i think i have 2 more new ones thanks
