Superstar 158EDX low audio and power on SSB.
Posted: Saturday 5th Apr 2008, 11:32
by Chevin
Superstar 158EDX
PCB EPT690010D
PLL MC145106
The trouble is low audio no SSB I can only get about 4 watts but AM/FM is ok 10 watts and nice and loud.
I have tried adjusting the ALC but make no difference and there is a bit of a carrier on SSB about 1/8 watt.
Can anyone help?
I would Rick to fix it but he is very busy.
Re: Superstar 158EDX low audio and power on SSB.
Posted: Tuesday 8th Apr 2008, 0:33
Try replacing the balance modulator, this is an all too common problem with the new type BM chip. Do not try to replace it with the old type BM (AN612) as it will not work without changing components.
I am sorry I could not repair the radio for you as I have lots of work at this time.
Posted: Monday 14th Apr 2008, 19:56
by Chevin
Rick wrote:Try replacing the balance modulator, this is an all too common problem with the new type BM chip. Do not try to replace it with the old type BM (AN612) as it will not work without changing components.
You was right it was balance modulator.
Thanks Rick for all your help.
