2950 with a squeal in the RX
Posted: Thursday 5th Jun 2008, 15:43
by falcon505
Hi all me agen I have a Rci 2950 with a bad squeal the squeal is at a steady volume even if the volume is tured up or down other than that the radio works fine full TX and good Rec. I am thing it is a voltage problem NEED HELP.
Thanks Falcon505 (mike) :( :(
PCB # is ept295013z The squeal is in the AF part of the Rec.
Re: 2950 with a squeal in the RX.
Posted: Thursday 5th Jun 2008, 20:47
Read this before you post www.radiomods.co.nz/forum/viewtopic.php?t=312
What is the PCB number?
