Talkback, frequency conversion (hi and low), 10khz switch, variable dead-key and modulation, and now im trying to unlock the clarifier. I've got another 148 that came with the clarifier already unlocked and the center is at 12 o'clock. Last night I did the clarifier mod on my new 148 but there are a few problems.
The center is at 9:30 and when i key up, it takes a second for it to settle on frequency. For example: When keyed up, it will go from 27.1152 to 27.1150 in about 1 second. I read somewhere that after this mod is done, the radio needs to settle for a while. One page said 2 hours, another said 2 days. Im a little confused, anyhow this is what I did to unlock the clarifier:
1. Cut R44
2. Cut D52
3. Solder a jumper wire across R 174 (or remove it and put a jumper in its place)
4. Remove red wire that comes from the Fine tune pot from the board and hook it to the + side of C84
5. Change R175 to a 1KOhm
Is this a solid mod or does anyone know of a better way to unlock it and maybe get more slide?
thanks
