Radio Make and Model: Stalker IX
PCB Number: PC-385
Test gear available: Digital Multimeter, Frequency Counter
Symptoms: Very low, almost inaudible TX audio
What is working: Everything else.
What has been tried: Adjusted VR7 (ALC) with no change to symptoms
Did it suddenly happen ?: Don't know - just picked it up without any history to it.
Anything else that may be of help?: Came with non-standard mic, which I had to re-wire to suit.
On SSB there is virtually no deflection of the needle (either on the radio itself or on an external power meter) but I can hear the audio when listening on another receiver in the same room.
TX on AM shows 10w output on meter but again, very very low TX audio.
Any assistance would be greatly appreciated.
Stalker IX low TX audio
Re: Stalker IX low TX audio
Hi Animal, they come with a mic that has gain adjustment on them, maybe thats a clue for you, unless of course you already knew that!
cheers
johnno
cheers
johnno
Animal,
Have you adjusted the AMC VR2 front right corner ?.
Thanks for the reply Dave.zodiac wrote:Animal,
Tried that today & still sweet FA!
Output must be milliwatts in ssb - the needle just to say moves on the inbuilt & an external meter.
Definitely audio on another receiver when TXing into a dummy load though - I might try another mic to see if that's the problem???
Try turning down the AM TX power to 4W and see if the AM TX audio comes right, 10W is too much, if the power output does not change when the VR as adjusted it gives a clue as to where the problem may be.
Cheers Scott (I should have noticed thatThe Defpom wrote:Try turning down the AM TX power to 4W and see if the AM TX audio comes right, 10W is too much, if the power output does not change when the VR as adjusted it gives a clue as to where the problem may be.
Anyway, adjusted TX output to 4w & re-checked but symptoms are still the same on both AM & SSB
Maybe it's the mic???
