Alignments
Galaxy DX2547 Alignment
REQUIRED TEST EQUIPMENT
  1. DC Power Supply (13.8VDC, 10A)
  2. RF Wattmeter (100 MHz, SOW)
  3. Multimeter (Digital)
  4. Automatic Modulation Meter
  5. Audio Signal Generator
  1. Frequency Counter (100 MHz)
  2. RF Signal Generator (100 MHz)
  3. Automatic Distortion Meter
  4. Oscilloscope (50 MHz)
  5. Sinad Meter
ALIGNMENT PROCEDURES
This transceiver has been aligned at the factory and does not require any adjustments at installation. The required test equipment listed is used for the test setup or alignment shown in Figure 4-1 Transmitter Test Setup and Figure 4-2 Receiver Test Setup. This test setup is used in part or total during the following adjustments. Refer to Page 43 for adjustment location.
PLL ALIGNMENT
ITEM U.U.T. (UNIT UNDER TEST) SETTING ADJUST
POINT
MEASUREMENT
Regulator
Voltage
Connect Voltmeter positive lead to power switch.
Connect Voltmeter negative lead to PCB ground.
VR701 13.8 VDC
VCO Disconnect 'short PCB' from TP7, TP8 and TP9.
Set radio to CH 1 AM RX mode.
Connect Voltmeter to TP2.
L14 2.5 VDC t 0.1
Set CLARIFIER Control to 12 o'clock.
Connect Oscilloscope to TP3.
L15  Adjust for max.
Connect Frequency Counter to IC3 Pin 8 VC1 10.2400MHz t 20Hz
 AM Frequency Set radio to CH 1 AM RX mode.
Connect Frequency Counter to TP3.
L20 16.2700MHz t 20Hz
USB Frequency Set radio to CH 1 USB RX mode.
L21 16.2725MHz ± 20Hz
LSB Frequency Set radio to CH 1 LSB RX mode.
L22 16.2675MHz ± 20Hz
TX Offset
Frequency
Set radio to CH 1 AM TX mode.
VR7 16.2675MHz t 20Hz
AM OSC Set radio to CH 1 AM TX mode.
Connect Frequency Counter to TP5.
L23 10.695OMHz ± 10Hz
USB OSC Set radio to CH 1 USB TX mode.
Connect Frequency Counter to TP6.
L24 10.6925MHz t 10Hz
LSB OSC Set radio to CH 1 LSB TX mode.
L25 10.6975MHz:t 10Hz
TRANSMITTER ALIGNMENT
BIAS Current Set radio to CH 19 USB TX mode.
Modulation Off.
Connect current meter to TP7(+) and TP9
Connect current meter to TP7 (+) and TP8
VR12
VR10
50 mA
100 mA
SSB APC Set radio to CH 19 USB RX mode.
Connect Multimeter to TP7.
VRI7 12.5 VDC
SSB TX Power Connect "short PCB" to TP7, TP8 and
Connect RF Power Meter to antenna jack.
AF signal 30mV, 1 KHz to microphone.
Set RF PWR Fully Clockwise.
Set MIC GAIN Fully Clockwise.
L40,L42,
L43,L44
MAX > 12W
Spurious Emission
Minimum.
Balance Power
Between CH1 and
CH4O.
SSB ALC Set radio to CH 19 USB TX mode.
AF signal 3OmV, I KHz to microphone
VRI3 11.5 W
SSB Carrier
Balance
Set MIC GAIN Fully Counter Clockwise.
Connect Oscilloscope to antenna connector.
VR6 Spurious Emission to
Minimum.
AM TX
High Power
Set radio to CH 19 AM TX mode.
Modulation Off.
VR14 3.8 W
AM TX
Low Power
Set RF POWER fully counterclockwise. VR18 0.5w
RF Power
Meter
Set RF POWER fully Clockwise.
Set SWR/MOD/PWR Switch to PWR position
VR9 For a needle reading
of "4" on TX PWR
scale.
AM Modulation
Meter
Set MIC Gain fully Clockwise.
Set SWR/MOD/PWR Switch to MOD position
VR16 For a needle reading
of 95% on the
Modulation scale.
Frequency
Counter Adjust
 Set radio to CH 19 AM RX mode
 VC1 on
frequency
counter
PCB.
Display should be
27.1850
RECEIVER ALIGNMENT
AM Sensitivity Set radio to CH 19 AM RX mode.
Set RF GAIN Fully Clockwise.
Set SQ Fully Counter Clockwise.
Set VOL Control at 2 o'clock.
Set NB/ANL switch to OFF position.
Set TONE Fully Clockwise.
Connect RF SG to antenna jack
Frequency 27.185 MHz, lmV. Mod 30%.
L2,L3,L5,L6,
L7,L8,L9,L10
Audio Output > 2V
S/N > 10 dB.
Set radio to CH 40 AM RX mode.
RF SG setting 27.405 MHz.
RF SG setting 26.965 MHz.
L5,L6 For Balance Between
CH 1 and CH 40
USB Sensitivity Set radio to CH19 USB RX mode
Set VOL Control Fully Clockwise.
RF SG setting 27.186 MHz, 0.5uV. Mod off.
L11,L12 Audio Output > 2V
S/N > lOdB
LSB Sensitivity Set radio to CH19 LSB RX mode
RF SG setting 27.184 MHz, 0.5uV. Mod off.
S/N >lOdB.
NB Adjust Set radio to CH 18 AM RX mode.
RF SG setting 27.185 MHz, 1000mV Mod off.
Set NB/OFF switch to ON position.
Connect Multimeter to TP1 (D2 cathode).
L1  DC Voltage to max.
(> 2.OV)
AM Squelch Set radio to CH 19 AM RX mode.
Set SQ Control Fully Clockwise.
RF SG setting 27.185 MHz, 2OmV. Mod 30%.
VR4 Adjust very slowly
until squelch just
closes.
SSB Squelch Set radio to CH 19 USB RX mode.
RF SG setting 27.186 MHz, 20 mV. Mod off.
VR3 Adjust very slowly
until squelch just
closes.
AM S-Meter Set radio to CH 19 AM RX mode.
RF SG setting 27.185 MHz, 100mV. Mod 30%.
VR1  For a reading of "9"
on the "S" scale.
SSB S-Meter Set radio to CH 19 USB RX mode.
RF SG setting 27.186 MHz, 100mV. Mod off.
VR2 For a reading of "9"
on the "S" scale
This counter shows the number of hits since the 28th January 2002
Go Back To The Alignments Page
Go Back To The Home Page
http://www.radiomods.co.nz/
