Ranger RCI-2950 DX and RCI-2970 DX Alignments
Adjustment
ItemSettingAdjust PointMeasurement
PLL 2 AlignmentSet radio to AM RX mode.
RF SG setting at 24.000 MHz.
RF SG setting at 32.000MHz
Connect Multimeter to TP10
L14
1,0V DC +/- 0,1V
<4,5V DC
PLL 1 AlingnmentSet radio to AM RX mode.
RF SG setting at 24.000MHz.
RF SG setting at 32.000MHz.
Connect Multimeter to TP11.
L14
1,0V DC +/- 0,1 V
<6,5V DC
Base FrequencySet radio to AM RX mode.
Set radio to AM TX mode.
Clarifier setting in 12 o`clock.
Connect Frequency Counter to TP16
VC2
VR8
10.100MHz +/- 10Hz
10.100MHz +/- 10Hz
AM frequency checkingSet radio to AM, RX and TX mode.
Connect Frequency Counter to TP3.
38.69500MHz
USB frequency checkingSet radio to USB, RX and TX mode.
38.69750MHz
LSB frequency checkingSet radio to LSB, RX and TX mode.
38.69250MHz
AM OSCSet radio to AM TX mode. Mod. off.
Connect Frequency Counter to TP5.
L18
10.69500MHz +/- 10Hz
SSB OSCSet radio tu USB mode. Mod. off.
Set radio to LSB mode. Mod. off.
Short TP6 to ground.
L19
L20
10.6975MHz +/- 10Hz
10.6925MHz +/- 10Hz
TX Pre-adjustSet radio to 28.000MHz, AM TX mode.
Modulation off.
Set radio to 28.000MHz, SSB mode.
Modulation 1kHz.
Connect Scope and Frequency Counter to TP17.
Set radio to 24.000MHz and 32.000MHz.
L18, L37, L35, L4
L35, L34
Maximum output.
Reduce Mod. signal and fine adjust to maximum output.
Maximum output and balance.
Power stage Pre-adjustSet radio to AM TX mode.
Set radio to SSB TX mode.
RF Power fully clockwise.
Connect Multimeter to TP8
VR15
VR18
6 V DC
12,5 V DC
BIAS CurrentSet radio to SSB TX mode.
Connect current meter to TP7(+) and TP9(-)
Connect current meter to TP7(+) and TP8(-)
VR13
VR11 and VR12
10mA
(50mA + 50mA) = 100mA
AM TX PowerSet radio to AM TX mode. Mod. off.
RF Power fully counter clockwise.
Connect "short PCB" to TP7 and TP9
VR15
VR19
10W (50W)
1W (8W)
24-32MHz
RF Power MeterSet radio to 28.000MHz, AM TX mode.
VR10Meter Indicator
AM ModulationSet radio to 28.000MHz, AM TX mode.
AF signal 30mV, 1kHz to microphone.
Mic. gain fully clockwise.
VR1790% Modulation
<7% Distortion
SSB TX PowerSet radio to SSB TX mode.
VR1425W (100W)
(24-32MHz)
SSB Carrier BalanceSet radio to SSB TX mode. Mod. off.
Connect Scope to Antenna Connector.
VR7Spurious Emission to minimum.
CW TXSet radio to 28.000MHz, CW mode.
Plug in CW key, disconnect Mic. jack.
AC Voltmeter
VR9200mV Sine Wave
Checking FM ModulationSet radio to FM TX mode.
Mic Gain fully clockwise.
4kHz +/- 1kHz Deviation
<7% Distortion
AM SensitivitySet radio to AM RX mode.
RF Gain fully clockwise.
NB/ANL switch off.
VOL control at 2 o`clock.
Connect RF SSG to antenna jack.
Frequency 28.000MHz, 30% mod.
RF SSG setting 24.000MHz.
RF SSG 32.000MHz.
L5, L6, L7,
L8, L9, L10,
L2, L3
L5, L6, L7
Audio output > 2 Volt
S/N > 10dB
Balance between
24 and 32MHz
USB SensitivitySet radio to USB RX mode.
Vol control fully clockwise.
RF SSG setting 28.001MHz, 0,25uV mod.
L11, L12
S/N > 10dB
LSB SensitivitySet radio to LSB RX mode.
RF SSG setting 27.999MHz, 0,25uV mod.
L11, L12
S/N > 10dB
FM DistortionSet radio to FM RX mode.
RF SSG setting 28.000MHz,
Mod. 3kHz 1mV
Mod. 3kHz 0,5uV
L4Distortion Min. and Output Max.
S/N > 20dB
NB AdjustSet radio to AM mode.
NB/ANL switch on.
Mod. 30%, 100uV
Connect multimeter to TP1
L1
> 2 Volt
AM SquelchSet radio to AM mode.
SQ control at fully clockwise.
RF SSG setting 28.000MHz.
Mod. 30%, 1mV
VR4
Slowly
Adjust very slowly until squelch just open.
SSB SquelchSet radio to USB mode.
RF SSG setting 28.001MHz.
Mod. off.
VR3
Slowly
AM S/RF Meter.
AM S-Meter
Meter switch at S/RF position.
Mod. 30%, 100uV
VR1Level meter indicate "6" on the scale position.
SSB S-Meter.Set radio to USB mode.
Mod. off.
VR2Level meter indicate "6" on the scale position.
This counter shows the number of hits since the 28th December 2000
Go Back To The Alignments Page
http://www.radiomods.co.nz/
