PALOMAR ELITE 450HD PART IDENTIFICATION
speedracer6g
First Name: Michael
Post by speedracer6g »
I have a palomar elite 450hd amp that had a resistor burnt to badly to identify. I cant find any schematic on this thing. Does anyone know what the value of R19 in this amp.
thanks,
Mike
zodiac
Re: PALOMAR ELITE 450HD PART IDENTIFICATION
Post by zodiac »
Mike,
Can you give a little more info as to the location of the resistor in the amp, as someone may be able to help you.
speedracer6g
First Name: Michael
(344.84 KiB) Downloaded 339 times
I replaced the part with a resistor already as seen in the pic i attached. R19 is beside the keying relay. when i key up but on med and high power it stays keyed after you unkey the transmitter. I dont think this is the main cause of this but i would like to get this part back to OEM. The amp seems to be self oscillating on high and med power on an antenna. It dosnt do this on a dummy load. I have tried it on my bench antenna and the customers. Any thoughts or suggestions??
thank you,
Mike
zodiac
Post by zodiac »
I've had the same problem many times, sometimes I fix them and sometimes I don't.
Try changing the relay switching transistor and the two IN4148 rectifying diodes to the base of the same transistor, it works for me now and again but not always.
speedracer6g
First Name: Michael
Thanks, I will give that a try and see what happens.
MIke
