NO rx audio on a Galaxy dx959
OK glad I could be of some help. It makes a change to help some one that does as one suggested. You can find the Aligning data on http://www.cbtricks.com/
222
Post by 222 »
for rick: well, i already screwed this up once...don't know where the unfinished post i composed disappeared to, but here goes tryin again...hope i've got this posted in the right place...sorry if not. i stumbled onto this forum while searching for help on a similar type of problem. i read & was impressed w/how you handled & solved the issue for shoebox 223 on his 959. i hope you have enough time to help w/this one...i have a cobra 2000 gtl w/etremely low (approx. 5-10%) rx audio level. rx signal ok...squelch seems ok...tx audio fine...still have to go back to check pa audio...problem same regardless of internal/ext. spkr, or sp1/2 jacks...checked for intermittents...audio ic, & transistors, etc. in vicinity, all seem to be running cool...have a schematic, but it doesn't identify transistor purposes, nor do i have a block diagram. i had hoped those might have helped point me to some recieve audio amps, associated caps, or something along those lines. would appreciate any help, ideas, direction...
222
Shoebox223
Post by Shoebox223 »
If Rick can't help you resolve the problem...chances are it can't be fixed.He is the best!
smokinone
First Name: Tim
Re: NO rx audio on a Galaxy dx959
Post by smokinone »
I'm a little late in the conversation, but having the same problem When I move the NF board the receive audio lowers, then gains. Is the NF board removed and discarded, then the jumpers installed, or jumper then put the NF board back in?
Thanks.
Also with the same radio, I have replaced the finals, and the audio chip 7222. Also have done an alignment. Problem is I have good audio in talkback, and good audio in PA, but when transmitting, audio is garbled or indiscernible. I have about 15-20 watts plus SSB out according to my meter, I haven't tried the AM audio but I was not able to make contacts on SSB although I had folks telling me they heard me, just couldn't understand my transmission. PLL and Transmit alignment is where it is supposed to be.
I might add this is a MOSFET radio, had no output until the new finals. I was thinking of replaceing the Q54 & 55, but the voltages are correct. Before I bought it someone had cut the audio wire from the mic board to put in a noise toy I think. I soldered it back together. The guy I bought it from had one for sale anyway, and this was a parts radio. No channels, clarifier is stock and as far as I can tell no modifications. Q39 was removed, and I replaced that with a new one.
Thanks in advance for the help.
Shoebox223
I removed the NF board
222
Post by 222 »
What is the "NF board referred to in this thread? Is it the "ANF/GNF" pcb? If so, is that a noise filter board, i.e., "automatic noise limiter/noise blanker/galaxy noise filter"?
Thx
Shoebox223
Yes..it is a noise filter...remove it and jump pin 2(input) to pin 4(output) with a piece of wire...had several of these go bad...that nf board didn't do much for noise anyway
http://www.cbtricks.com/radios/galaxy/d ... nf_pcb.htm
smokinone
First Name: Tim
Post by smokinone »
222 wrote:What is the "NF board referred to in this thread? Is it the "ANF/GNF" pcb? If so, is that a noise filter board, i.e., "automatic noise limiter/noise blanker/galaxy noise filter"?
Thx
I think it means "Non Functional" :D
222
Post by 222 »
Hmmmm. Seems odd. I have always loved the 959 since its inception. I never noticed any issue such as this (at least not that i remember) & i have dealt w/many of them. (not disputing, just havent run into it). I'm sure i have checked the functionality & effectiveness of the anl/nb (cant remember at the moment if theyre both there, seperately, on this radio or lumped 2gether or just 1 of those 2?) & i never noticed anything that seemed any more or any less effective, in noise filtering ability, compared to say...a 29. I dont see how i couldve missed it, if the anl/nb part didnt work or wasnt worth its button. The gnl (which i always thought meant galaxy noise filter) always has seemed to be one of those "hi pass" or hi freq filters. I never liked its "effect" on the sound, but it also, seemed quite effective (regardless of liking or not).
So anyway, are u guys saying its a connection problem, where this board plugs in...?....or some other malfunction of the boards components? If its been tracked to simply a connection problem w/the pins or something, i would think such could somehow be corrected fairly easily, unless of course, you ARE saying that the boards' function is so bad and/or trouble prone, and/or ineffective (as far as noise filters go), that its not worth even fixing the connections & better to discard for a jumper? Wow, im really surprised if thats the case, and i would like to hear back about my above comments.
Merry merry happy happy
smokinone
First Name: Tim
Post by smokinone »
Can't say what others are experiencing with this NF board, but mine was kicking in and out altering the output to the speaker. I could move it and the sound would come back, then it would go out again by itself. I removed it and put in the jumper now I have constant volume to the speaker. My connections were not the problem, but the module itself.
222
Post by 222 »
Thanx for the reply smokinone. I can understand how locating & removing the source of the problem was a positive, restoring good sound. But i am curious as to how u concluded that the boards connections were not the source of the intermittent sound, esp since u said someth to the effect of moving it (while its plugged in) resulted in the variable sound thing. In order for it to not be the connections, i would think it would have to be either a bad solder joint(s) somewhere on the board, or, even the rarity where a component has an internal intermittent, which certainly can be. Also, some of the electrical impulse noise that often gets into cb rx audio, can be real bad, very commonly...and most anl/nb circuits ive checked, against such noise, are usually VERY effective, often nearly eliminating that static, that comes on from so many sources...and so im curious if u were able to manipulate the board in such a way, that u could hear the level of effectiveness of the anl/nb, w/any significant electrical impulse noise present? I have developed a keen skill for "rooting out "intermittents" of all kinds & so this interests me for 1) where exactly is this intermittent (after all, it a great & very common radio w/a lg # in use & still being being made (i think), 2) what is the problem (if any) w/the effectiveness (or not) of the noise filters in this radio (aside from the intermittent issue) that would make some of you find it better to just discard it & make jumpers...i.e., are the working noise filters THAT POOR (performance-wise) that its not even worth finding/fixing the intermittent....and the radio gets left w/no noise filters at all? Or am i misunderstanding?.
Ho Ho Ho, hmmm hmm hmm..
smokinone
First Name: Tim
Post by smokinone »
I wish I could help you with all the specifics, but I am as GREEN a radio tech as can be. I look to experts on this forum and others for guidance. I know a little about soldering, I can align a radio with the freq counter and use a scope in a limited fashion. This radio I'm working on was dead when I got it and by cleaning up some one elses bad solder joints and repairing some obvious damaged traces I was able to get it to receive. After that I checked the bias of the finals and found those to be bad and replaced them with the IRF520's as the originals were. Got that working. When I took the front part of the radio off to get to the 20-21-& 22 coils for PLL alignment is when I noticed the sound dropped by about half. Poking around the NF I found restored the sound. I pulled it out and checked the traces on the circuit board and they were all good, as the NF modules legs looked good as well. I found this thread about problems with the NF board and put in the jumper and problem solved. I did notice however that AM'ers keying on the channel (38 LSB) the radio exhibited a louder and more prominent squeel compared to my Jackson sitting next to it for comparison. It may or may not be linked to the NB/ANL circuit, I don't have that knowledge at this time. This radio has several problems I'm trying to work out before possibly turning it over to a PRO. I tinker and sometimes get lucky, sometimes not...OK, most times not, but I do learn something every time I get into any one of the radios I've played with.
Now the problem I have with this radio is no intelligible audio out on AM or SSB, although I have a SSB carrier of about 20 PEP watts. I replaced the 7222 chip as well with no luck. The Q54 & 55 seem OK as the voltages are correct in the SSB and AM modes. Now I am looking for more guidance on this issue.
I wish I could be of more help to you but I'm sure one of the guys here can explain the NF circuit more clearly.
222
Post by 222 »
Hey smokin....sorry if i misled you on my point(s), or maybe you just misunderstood the thrust of my post (prolly comb. of both..), but i wasnt questioning or even commenting on...your abilities, expertise level, how you went about anything, intentions, or any of the other points about the radio, etc etc....
All i was trying to say...and it is as much me trying to find out about this particular radio issue (orig posted about), as offering any opinion....is that i saw a post about an intermittent rx audio issue & the expert advice about the nf board elimination & jumpers. I didnt recognize, right off, what was an "nf" board, but i thought about & asked if reference was to noise filter & was told it was. So my concern then was twofold: 1) how did you determine it was the board itself rather than the board connections (based upon your words that said that, while at same time saying that moving the board had an effect) & 2) i was both trying to ask (anyone) if there is an inherent uselessness, or at least a poor performance level, of this particular radio models' noise filter circuits (aside from the audio fading/nf board problem), because my experience had shhown that w/o any doubt, most anl/nb circuits are very effective & very much needed & very much used.
With those 2 main points in mind, i was wondering how hard (or not) it might be to correct the problem, rather than eliminating the board for jumpers, and/or maybe somehow implimenting an alternative noise filter, if the board problem cant be fixed for some reason. And please understand that those concerns were about this radio in general & my finding out more specifics about the issue, not directed at you, per se, or any of the good work you are obviously doing. I mentioned that i had dealt w/many 959s & never come across this & so wanted to get to the bottom of whats the cause & how to fix, if possible.
The way i see it is, either the board has some inherent connection problem & if so, shouldnd be too hard to fix. Or, as you stated, it is not a connection problem but rather some problem w/the board itself. If thats indeed the case, then its a good question i posed, about how that determination was made. And if it is the board itself, then im not looking at 1 right at the moment, but i assume it couldnt have too many solder joints too go over & maybe there would be the fix. Otherwise, keeping in mind that we KNOW from the description (moving around) & the jumper fix, that it is indeed a connection problem SOMEWHERE, so if its on the board, but not an easily correctable solder joint, then maybe a faulty component internally (and if its a common problem, then maybe a bad batch of a particular component?). I have seen this a few times (internally intermittent). If that was the case, (doubtful, in my opinion) then i know some of the galaxy ppl & i can almost gaurantee you, regardless of age, that if such was identified as being the case, that galaxy would not only replace the part, but would also correct the production problem. I realize that the jumper thing is a quick & easy fix, but i dont think its the best idea if at the cost of an otherwise effective anl/nb circuit. If we were talking about something much less important & useful, like lets say a delta tune on an am radio, that was causing a similar kind of problem, i'd say fine, get rid of it as doesnt do nuch anyway & the majority of cb owners dont use it & most dont even know what it does. But anl/nb filtering is a must, in my opinion.
So my questions & concern is academic & about the issue, not you or your work.
