Radio has only .5 watt output. Mod is good. SWR will not calibrate.Cked my antenna with another radio. SWR on the antenna 1.2.Mic is good. Radio also chirps on keyup. Recieve is great. I can read a schematic but I don't have one. I only have a VOM and Watt/Mod/SWR meter. Any ideas on where to look.Man date is 7/99
Thanks
Chuck
Cobra 29 NW ST low tx power/swr no calibrate
Re: Cobra 29 NW ST low tx power
Best to read this first as it help us help you http://www.radiomods.co.nz/forum/viewto ... STING%20!!
What is the PCB number?
You could just try replacing the final as it sounds like a blown final.
I do not know the ref number for your 29 NW ST but if it is the same as the 29 classic it is TR14 (2SC2078). Hope this helps.
The stock final is 2SC2078 but to try and get a bit more out for the radio some one has fitted a 2SC1969. It is up to you which one you fit, the gain you will get with a 1969 may if you are lucky maybe about 1 to 2 watts in my opinion I would just stick with the stock final.
RF Parts have them 2SC2078 and the Fake 2SC1969 in stock. I would not use the fake 1969 more trouble than it's worth. http://www.rfparts.com/2sc.html
Hi Rick
I checked them out today and they have a $25 minimum for ordering parts. I would have to order 5 of them. If I don't find it I will most likely do that and then I would be able to spread the cheer so to speak.
This is a link I found that might be of use to some of the members. It is a list for cb's,parts and accessories.
http://www.cbcintl.com/suppliers.htm#CB ... CCESSORIES
Chuck
Chuck
